Home > Technical (L405) > Can a L405 be towed
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Can a L405 be towed
Just watched a video from 4XOverland on youtube about issues with new Defender, one being it cant be towed as handbrake automatically comes on after 10mins. Is this the case with a L405? 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #672867 7th Sep 2023 6:57am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
He is right the electric brake will come on if it's not put in 'N' before the engine is turned off.
I found that out on my L322 2012 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #672868 7th Sep 2023 7:37am
Kot
Re: Can a L405 be towed
Recovery L405 CAUTIONS:
Make sure the vehicle recovery and/or transportation is carried out by suitably qualified personnel, and the vehicle is secured correctly.
The recovery agent must activate the transmission park release before recovery commences. Failure to
activate the transmission park release can result in serious transmission damage.
The vehicle should not be towed on all four wheels and should not be recovered with the front or rear
wheels suspended. Doing so can result in serious transmission damage.
The method for recovery and/or transportation of the vehicle is on a transporter or trailer designed for that purpose.
WARNING:
Make sure that the vehicle is secured with wheel chocks, then apply the Electric Parking Brake (EPB) or
firmly press the brake pedal. Two people are required for this procedure. Failure to do so can result in
unexpected movement of the vehicle, causing serious injury or death.
When recovering the vehicle, it is essential that the transmission park release mechanism is activated. Activating the
transmission park release mechanism locks the transmission in Neutral (N) and prevents the transmission from
automatically selecting Park (P). 2018 SE SDV8 4.4 Byron Blue
Post #672869 7th Sep 2023 7:44am
wayneg
As the man says its unbelievable that an "offroad" vehicle cannot be towed out of an offroad situation.
So on the l405 where is the Transmission park release and would putting the handbrake into service mode via diagnostics stop it coming on?
Remember on the P38`s you just had to put in a fuse, 11 from memory. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #672874 7th Sep 2023 9:03am
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
You can tow it (recover it from an off road situation) as long as the engine is running though, surely? in which case the vehicle would presumably be in gear (forward or reverse) ready to try and move under its own steam FFRR SDV8 Autobiography
Post #672876 7th Sep 2023 9:10am
You could simply pull the gearbox neutral release and with the handbrake in the off position, unplug the handbrake motors behind the rear calliper's... Thumbs Up
Post #672877 7th Sep 2023 9:11am
GraemeS
Mine doesn't automatically apply the EPB. It's a CCF option that isn't enabled on mine.
Post #672878 7th Sep 2023 9:13am
caymanblack
I leave mine in the garage with the HB off, I hold the park Brake lever down until I switch the engine off and this keeps it off.
Question overfinch modified
Post #672880 7th Sep 2023 9:32am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
If you pull the park release, I can't see that it's much different from any other automatic 4x4 - if you flat-tow it for any distance with the props connected, you'll destroy the gearbox anyway.
Post #672899 7th Sep 2023 1:07pm
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
I always leave mine in the garage, in park. The handbrake is off. Is this correct. My garage is level. 2013 SDV8 4.4 SE Luxor.
1960 Series 2 88 inch diesel.
1955 Series 1 86 inch petrol.
Post #672901 7th Sep 2023 1:09pm
Philip
Also, that 4xoverland bloke has a massive chip. Most odd.
Post #672902 7th Sep 2023 1:22pm
Kot
Or you could follow the manual Whistle
EPB CAUTION:
This procedure requires the vehicle in the Park or Neutral position, with the ignition turned ON (the engine
must be OFF) and the parking brake system released.
NOTE:
This procedure allows the parking brake to be released when recovering the vehicle.
Activation
1 Press and hold the parking brake switch in the release position.
2 Wait 2 seconds.
3 Press and hold the accelerator pedal in the wide open throttle position.
4 Wait 2 seconds.
NOTE:
5 An audible noise will be heard to confirm that the parking brake has been released in Service Mode.
Turn the ignition Off and back On immediately.
6 Release the accelerator pedal and release the parking brake switch to the neutral position
Deactivation
CAUTIONS:
must be OFF) and the parking brake system in Service Mode.
Once the vehicle has been recovered, the Service Mode must be cancelled.
NOTES:
If this process is followed, new electronic park brake actuator O-ring seals are required.
To be carried out in the event that the vehicle has no electrical power. 2018 SE SDV8 4.4 Byron Blue
Post #672922 7th Sep 2023 3:42pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
On a shooting trip a while back, I had to be towed out (wet grass, adverse slope and road tyres…..). The front valance was removed, a rope attached to the towing eye and then attached to the gamekeeper’s Defender. Engine running in my car, left in neutral and pulled away. Once on level ground, engaged park, removed rope and proceeded normally (GGS engaged, low range just to be sure.).
Post #672924 7th Sep 2023 3:48pm
Salsbury
Canada 2014 Range Rover 5.0 SC V8 Barolo Black
Full of it, he is.
Post #674598 30th Sep 2023 5:19pm
