Home > Maintenance & Mods (L405) > 2013 FFRR Vogue SE
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
2013 FFRR Vogue SE
Just bought an L405 from eBay, probably not my best decision but gradually working my way around the car seeing all the bits I need to fix or weren't as described in the advert.
Does anyone recognise these bits and can tell me what they are for?
The black brackets are attached just behind the rear sets in the boot area.
The plastic sprung things were just lying in the boot.
Thanks.
Post #674316 26th Sep 2023 1:04pm
The bracket is not original - it looks like some sort of dog guard fixing.
The flaps would go in the holes just above the brackets - they would match the flaps on the parcel shelf for the reclining rear seats.
Post #674318 26th Sep 2023 1:13pm
Mike Edwards
That's great. Thanks.
I did think the brackets looked a bit agricultural.
Post #674319 26th Sep 2023 1:17pm
I don't know how the flappy things go back in as I've never taken mine out.... I assume they were removed as part of the dog guard installation.
Do you have the parcel shelf ?
Post #674320 26th Sep 2023 1:26pm
Post #674322 26th Sep 2023 1:51pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
@mike-edwards
Don't worry about the eBay stigma Mike. I bought mine from eBay 5 years ago and it's been great, only inlet manifold and oil cooler needing to be changed. Done over 40,000 miles and still as reliable as ever since the fixes. Jut did 2000 miles to France and back without a hitch.
Enjoy yours!
DB
Post #674324 26th Sep 2023 2:19pm
Mike Edwards
Thanks. I suspect I've been lied to regarding this one but we'll see...
Post #674377 27th Sep 2023 12:12pm
Mike Edwards
Have got the parcel shelf although it's not fitted at the moment.
Post #674378 27th Sep 2023 12:12pm
Should be good then - if you were buying one, you'd need to ensure it had the flappy bits for the reclining seats as not all do Thumbs Up
Post #674393 27th Sep 2023 4:40pm
Mike Edwards
Hi,
Which flappy bits are those? The ones from the first post?
Thanks.
Post #674396 27th Sep 2023 4:58pm
Front edge of the parcel shelf should have flappy bits - shown in the photo above Thumbs Up
When the rear seats are in their more upright position the fill the gap, but allow them to recline.
Cars with non-reclining rear seats don't have them on the parcel shelf as seats are always in the more upright position.
Post #674398 27th Sep 2023 5:13pm
j_rov
the right angled bracket is for the genuine dog guard. I've been looking for the part that's behind that panel if you'd like to sell... It's another right angled part that fixes to the side behind the seat belt finisher __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #674443 28th Sep 2023 9:02am
Mike Edwards
If I can ever work out how to fit the trim back on I will have a go at getting the other side off.
Post #674463 28th Sep 2023 3:39pm
j_rov
that's exactly what I'm after if you'd be willing to part with them...
To refit the trim, you jiggle the bottom into the slot along the edge of the boot floor while lining up the pins along the underside of the shelf, then just tap in.
 __
Land Rover History:
1976 Series 3 2.25
Post #674464 28th Sep 2023 3:42pm
j_rov
Do you also have this tie down point extension?
 __
Land Rover History:
1976 Series 3 2.25
Post #674465 28th Sep 2023 3:46pm
