Home > Technical (L322) > Rear pinion seal replacement
Henrik07
Norway 2007 Range Rover Vogue TDV8 Santorini Black
Hi guys,
My car is a 2007 tdv8 Vogue.
I have a bit of a leak from the rear diff pinion seal. Have any of you done the replacement? Anything I should know before getting stuck in?
Thanks!
Henrik
Post #674291 26th Sep 2023 9:41am
GraemeS
Check that the breather isn't blocked if not already done.
Post #674341 26th Sep 2023 8:50pm
Henrik07
I will indeed. Where is it located, if you don't mind?
Post #674344 26th Sep 2023 9:09pm
GraemeS
Microcat 2012 shows it running up high, probably with the fuel filler pipe.
Post #674349 27th Sep 2023 1:08am
