Home > Maintenance & Mods (L322) > B100D-96 Column Lock Authorisation - SOLVED (for now!) |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 |
Are you sure your start/stop button hasn't just worn? 2015 Range Rover Autobiography 4.4 SDV8 |
22nd Sep 2023 3:03pm |
fmgl322 Member Since: 18 Apr 2022 Location: Koblenz Posts: 63 |
The button is fine. When the code is cleared it starts/stops instantly. If/when the code reappears, it's as if it's dead (until it starts that is!). -------------------------
22nd Sep 2023 3:12pm |
And simple things like when the batteries were last changed in the key fobs?
22nd Sep 2023 3:17pm |
Both key batteries were changed when this malarky started (Duracell!) and it made no difference. Keys are working fine. -------------------------
22nd Sep 2023 3:19pm |
Today’s update: a driver’s door communication error appeared - any link? -------------------------
23rd Sep 2023 2:23pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2554 |
What is the fault code? |
23rd Sep 2023 9:04pm |
B1108-15 Driver’s door central locking motor - general electrical failure.
24th Sep 2023 11:52am |
It will be reporting a real situation but it could be caused by either a wiring fault or a motor fault, so should be considered in light of the other behaviour but could also be the cause of the other behaviour. I would persue the door locking fault because there is something concrete to chase, at least whilst the fault persists. |
25th Sep 2023 5:30am |
Success! Can’t say exactly what did it, but I dismantled, unplugged, cleaned and sprayed all connectors related to starter button/door mechanisms/steering column/immobiliser/ and even scrubbed and starter motor and battery terminals/fuse box connections. Since then there have been no phantom errors and the car starts faster than ever on the button - every time. I’m going to perform similar actions moving forward on any jobs I do around the car as a while-I’m-in-there precaution. One day I’ll have all connectors cleaned and sprayed!
26th Sep 2023 9:47am |
Great! Did you clean the temrinals on the distribution block behind the battery as that one seems to be a regular culprit for general electrical problems. |
26th Sep 2023 8:49pm |
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 153 |
What and how best to clean these please? 2012 4.4 TDV8 Vogue Santorini black ivory leather |
26th Sep 2023 9:06pm |
I haven't had to clean mine yet but the battery will need to be removed to gain access, then just remove the nuts and terminals to clean all the contact spots with a light sanding. |
27th Sep 2023 1:12am |
