![]() | Home > Technical (L322) > Arnott fakes CVD suspension. AS-2798 and AS-2797 |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 411 ![]() ![]() ![]() |
Interesting...
Shaunj69 Member Since: 25 Feb 2022 Location: Bristol Posts: 57 ![]() ![]() ![]() |
Hi mate Where did you get those struts and where they advertised as CVD. Sorry to ask but i am very interested L322 TDV8 2011 Autobiography Working for an OE aftermarket car parts suppler |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 163 ![]() ![]() ![]() |
Response from arnott:
They advise it for vehicles with Variable Damping System (VDS) and cross number LR032567 https://web.tecalliance.net/arnott/en/part...roups:4118 they even show this weird part in instruction manual
but in any place tell it is fake |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 513 ![]() ![]() |
Wow |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7897 ![]() ![]() ![]() |
Just playing devils advocate here, I might have read it wrong, but are they not suggesting to use a different part number if you want the features of OE?
they dont tell in any place it is NOT cvd. If you compare reman and new spare parts, you dont find any difference in description clearly tells one is cvd and another is not. Price is the same as new bilstein with cvd. They mention in installation manual "connect plug into the damper"
The only difference I can see is that one comes with the strut top that might have resistor in to stop dash errors when the strut, probably non CVD, is fitted.
The other comes as a strut without the new strut top, and it might not need it, as that shock might be proper CVD.
Both would be for cars with CVD, but with one of them you would lose CVD functionality, and that’s the one they said is tuned by Arnott (instead). Again, I might be way off…. They have definitely not explained it very well if that is indeed the case and I understand how you feel hacked off and misled. Does the above sound plausible given pics and their reply? 2011 Range Rover Vogue SE 4.4 TDV8 Previous cars : 2003 Range Rover Vogue TD6 1999 Discovery Td5 ES 1995 BMW M5 3.8 6 speed 1992 Range Rover 3.9 Efi Vogue 1992 BMW M5 3.8 1988 BMW 735i SE 1989 Ford Sierra XR4x4 2.9i 1981 Ford Fiesta Supersport |
Ennoch Member Since: 26 Dec 2015 Location: Scotland Posts: 109 ![]() |
There wouldn't be anything wrong with them offering this for those who wanted to 'cheat the system' so to speak, especially if there was a big variable in price. However, they do not state that you lose the VDS setup, and the price is close to a proper Bilstein (especially given what you're missing). Therefore you have to think it's pretty disingenuous behaviour, if not outrightly fraudulent. |
LandyManSam Member Since: 10 Jul 2019 Location: Wild West Ireland Posts: 51 ![]() ![]() ![]() |
This is crazy. If they're not clearly stating that this is a "cheat" device and will disable the CVD system, it's definitely fraudulent and downright stupid.
especially the price is double if compare to standard shocks. 2,2Ohm, 5W resistor costs less than 0.5 GBP.
I was only speculating given what was posted above about what they advised coupled with the pics. I might be way off…..
Jon G Member Since: 02 Dec 2016 Location: Leicester Posts: 120 ![]() ![]() ![]() |
Just bought a Car with one of these fitted.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1291 ![]() ![]() ![]() |
Jon G, which side are you after? I've got a near side one. Bilstein, date 2016. |
Hi Kevin
