Home > Technical (L322) > Select reverse and main beam comes on
Rattle
United Kingdom 2006 Range Rover SE Td6 Zermatt Silver
I have just purchased my 2006 L322 ,but has come with no owners handbook, The question I have is that when the headlights are on and I select reverse they appear you go onto main beam until I select either Park/Drive /neutral is this normal or have I a problem with part of the electrics ?
Post #673962 21st Sep 2023 10:26am
Definitely not normal or a least my don’t do that and never have. Thumbs Up
Post #673983 21st Sep 2023 3:50pm
Kot
So what happens when you flash someone with your main beam? Gearbox engages reverse? Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #674029 22nd Sep 2023 12:38pm
garyRR
Is it the main beam or the fog lights which come on?
Has it been like it since you've owned the car? I wonder if someone has fiddled with the front fogs and wired them to come on in reverse as parking lights, to mimic what modern cars do?
Otherwise, it's very odd. Having checked the electrical diagrams, I can't see any multiplugs carrying the high beam and reverse signals which may have been damaged or corroded.
It could point to the LCM. 2015 Range Rover Autobiography 4.4 SDV8
Post #674042 22nd Sep 2023 2:53pm
p38arover
Australia
I added an LED flood reversing light (via a relay) on my 2003. If my headlights are on, selecting reverse turns on the main beam.
I haven’t got around to sorting that yet. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #674075 23rd Sep 2023 6:08am
Water ingress in the LCM? Its behind your bonnet pull panel Thumbs Up
Post #674132 24th Sep 2023 12:00pm
Rattle
Post #674205 25th Sep 2023 10:09am
p38arover
Australia
How the heck does water get into the LCM? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #674226 25th Sep 2023 1:22pm
