Home > Technical (L322) > Wedge key? |
Jomo Member Since: 26 Mar 2018 Location: Maidenhead Posts: 32 |
Hi all.
1st Jul 2023 6:11pm |
So I took the step off the car, thoroughly degreased it, let it soak in WD40 for a few weeks and then lubed it with silicone spray. Tested it by putting a 12V battery across the yellow and orange wires and it all worked perfectly, smoothly opening and closing fully.
24th Sep 2023 4:16pm |
landy95 Member Since: 04 Aug 2021 Location: Hall Green, West Midlands Posts: 79 |
There shouldn't be any wear to the wedge key as it's not a moving part, it literally locks the motor shaft to the hinge on the bracket. I suggest you remove the the motor from the bracket and check for corrosion of the shaft where it locates in the bracket. Clean it out lubricate and reassemble. Also own a 1976 Land Rover 101 3.5 V8.
24th Sep 2023 6:50pm |
That all makes sense. Thanks for the advice. I'll try what you suggest. 2011 5.0 S/C |
25th Sep 2023 10:54am |
