Home > Technical (L322) > CVD Shocks
Jon G
United Kingdom 2011 Range Rover Vogue 4.4 V8 Baltic Blue
CVD Shocks
Just bought a 2011 4.4 TDV8 and it has an Adaptive Dynamic warning on the dash.
Just been looking today to see what the fault is and noticed it has different tops on the Shocks.
Looks like one has been replaced at some point but I’ve never come across this before.
Non Standard (Drivers Side)
Standard (Passenger Side)
Anyone seen this before ? 2001, 4.4 TDV8, Vogue, Baltic Blue
Post #674145 24th Sep 2023 5:53pm
mjdronfield
You can buy a repair kit from Land Rover that has better wires in it. You def need one for the non standard side as least Id say.
That wiring is def not factory….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #674148 24th Sep 2023 6:18pm
mjdronfield
https://www.lrparts.net/lr032839-suspensio...-2012.html
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #674149 24th Sep 2023 6:26pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
driver side if fake arnott cvd.
take a look:
https://www.fullfatrr.com/forum/topic67977.html
If you check faults i bet you will get
Quote:
Front right damper solenoid C110D- 14 or 19
or both faults.
Post #674166 24th Sep 2023 9:35pm
Jon G
Thanks for putting the Link up.
Done a bit more testing as I have a spare shocker in the Garage.
Plugged the wiring onto that one started the Car and the Warning Message cleared, so I now know it’s deffo the cause of the issue.
So next weekends job is to change the strut out and hopefully that will fix the issue.
Think I’ll get a repair kit and fit some new wiring as well to be sure 👍👍 2001, 4.4 TDV8, Vogue, Baltic Blue
Post #674167 24th Sep 2023 9:38pm
GraemeS
Australia
The connector and wiring is standard factory, just that the connector is visible being plugged into the fake block rather than plugged into the shock itself and therefore hidden by the genuine block.
Post #674174 25th Sep 2023 6:23am
mjdronfield
Ah yes, see that now….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #674191 25th Sep 2023 9:19am
GraemeS
Australia
It certainly looks unusual.
Post #674204 25th Sep 2023 11:02am
Jon G
Thanks for all tha replies guys, I agree it does look like it’s a Fake one and will be changed at the weekend 👍👍👍 2001, 4.4 TDV8, Vogue, Baltic Blue
Post #674246 25th Sep 2023 6:59pm
