![]() | Home > Technical (L322) > Aux heater controls ? |
KF Member Since: 19 Jul 2022 Location: Kerava Posts: 45 ![]() ![]() ![]() |
There should not be anything related with Webasto near LH front light, heater is mounted under the battery base plate and it is serviced and visible via wheel well with plastics removed.
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 178 ![]() ![]() ![]() |
Ah right, seems I'll need to invest in a GAp tool after all (as I've secretly expected... )
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 697 ![]() ![]() ![]() |
The Fuel Burning Heater wasn't fitted a standard in all markets - only "cold climate markets".
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 173 ![]() ![]() ![]() |
You don’t need Gap tool to activate the FBH if it’s already fitted to the car, you can turn it on and off via the timed climate control menu on the infotainment screen. If you have a GAP tool you can activate the FBH to do a diagnostic check on it. I’m fairly sure if it’s fitted then it will produce both cool air and heat, best way to tell if it’s fitted as previously mentioned is to check the rear fuse compartment and see if the remote starter is there. It’s a black box with cables coming out the bottom fitted closer to the rear indicator light. You can use remote which is more a more easy way to turn it on or off and they are available on auction sites.
Always nice when there is only one solid truth and people are convinced about it.
Check the build spec.
Well, There is a FBH under the battery tray on a LHD L322 ! Huzzah !!! ![]() I was able to use a el cheapo endoscope cam on my phone to find it with a little faffing about. Also just agreed to buy a Webasto module that should work on this type of heater and has the ability to start the heater via a app on the phone. Webasto TC4 Advanced it's called. We'll see how that goes so I think I'm going to order a GAP IID tool as well. Edit: The receiver for the FBH was not mounted at the factory so fingers crossed the other receiver will, but I'm fairly sure it will as in all fairness, it's just a fancy switch with a remote. ![]() |
