![]() | Home > Maintenance & Mods (L405) > Service Intervals - WTF? |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1317 ![]() ![]() |
The more the load in the car the better the chance of achieving 250C which of course will stretch out the distance between AR's but difficult to achieve keeping to speed limits |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1689 ![]() ![]() ![]() |
Interesting reading, but can someone please explain to me exactly how unburned diesel gets into the sump from the Catalytic Converter?
Post injection does get past the piston rings when the engine is stopped, same as if an injector failed and dribbled fuel into the cylinder this was always the usual way before dpf's were fitted.
@Kot:
When the engine is running the secondary injected fuel is burnt off as it's injected later and it is intended to be burnt in the dpf not the cylinder.
Spleen Member Since: 11 Feb 2022 Location: Wilts Posts: 92 ![]() ![]() ![]() |
Today I did this:
Well done I can see your smile of satisfaction from here |
V8Russ Member Since: 22 Jul 2023 Location: Yateley Posts: 29 ![]() ![]() ![]() |
I know, I'm on my 3rd or 4th in 7000 miles.
I'm thinking I may well let it go next year as I've not used it much this year and I'm likely to use it even less in 2024. Whilst I love the car I'm also getting increasingly resentful at how much it costs to run with ever increasing insurance, warranty, marked depreciation and of the course multiple oil changes. It all adds up and it just takes the shine off.
I agree but its difficult to find a match with a different manufacturer. Anything premium will always costs more to buy and run.
The 7% or 10% doesn’t really matter so much, the point is not to let the dilution get that high in the first place, by changing the oil yourself (for about £35 if you have the kit). Ensuring the oil dilution is minimal, by more frequent oil changes and monitoring the regen status to prevent failed regens, is the way to go to reduce wear and tear and prolong the life of your engine. |
Malbro Member Since: 22 Mar 2023 Location: Cumbria Posts: 17 ![]() ![]() ![]() |
I have been using the Kot Kit over the last couple of weeks resulting in no missed regens |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3896 ![]() ![]() ![]() |
Just an observation, my indie simply does a big service and a little service alternately every 12 months and I change the oil between services. I tried to follow the JLR service sheets but I've already done the 144,000 mile service despite having done nowhere near those miles as a result of having it serviced annually. But all fluids have been changed (gearbox, diff etc) and my "knuckles"checked. Geoff |
