Home > In Car Electronics (L322) > SOLVED - Temperature error fault
PlaceDuPilori
United Kingdom 2012 Range Rover Vogue TDV8 Santorini Black
So I have a 2009 TDV8 and have a similar issue. Does the bypass loop fit on each of the modules or can it be applied in the boot? IE/ does the dash have to come out here to test which component might be triggering the "temperature error"?
Post #673695 18th Sep 2023 1:15pm
garyRR
Yes, all the rear modules can just have a fibre optic loop plugged in one-by-one.
If, and once you've ruled out all of these, you can access the fibre optic plug to the CD changer by removing the glove box. You don't need to remove the whole dash to get to it. 2015 Range Rover Autobiography 4.4 SDV8
Post #673739 18th Sep 2023 9:38pm
PlaceDuPilori
Thank you so much Gary. So far it does appear to be the Hybrid TV Module - because the temperature error has not re-appeared since the loop was put in place over those connectors. Fingers crossed it stays that way!
Post #673775 19th Sep 2023 12:00pm
