![]() | Home > Technical (L405) > MY18 L405 P0047 |
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 294 ![]() ![]() ![]() |
Mine has just done this, same code, no obvious symptoms. Have cleared code for now, will monitor. I wonder if mine has had the recall done 🤔 Edit/update: so it seems the fault is persistent, same code. Easily cleared but needs sorting. I’ll call the original dealer tomorrow and see if they can confirm if N375 has been done as a recall, otherwise it will be a trip to the local Indy to see what’s up. FFRR SDV8 Autobiography |
Another update: Dealer surprisingly helpful, confirmed the N375v2 Service Instruction has already been completed when the vehicle was being prepped for Approved Used sale. Even checked the parts had been ordered/fitted etc. on their records.
Just been to helpful indy garage. He confirmed all my thinking, it's defo oil in that loom but he said it's worth trying a new 'mod' loom first as the level sensor is fully functional and he also said a lot of the time when the dealers fit the mod they don't clean out the existing wiring harness. I also need an ECU update so hopefully that will help with service intervals. Booked it in to be done FFRR SDV8 Autobiography |
Update! So I got the "mod"/recall loom replaced again at my trusted indy today. The plan was for him to re-do the job, but this time take time to really clean out the wiring properly with brake cleaner and an air line. Apparently (despite the approved used LR dealer confirming it!!) The mod/recall had NOT been done! So either the service guy on the phone did a good job of telling me porkies, OR some LR tech got an hours feet-up time when he was supposed to be fitting this mod as the parts and the book time were charged to this car as part of its pre-approved prep! For now I'm just happy to know where I'm up to and that the mod has been done properly. The warning lamp is off for now!
Warning lamp returned. What is not sure now is whether it's because oil is tracking or if the turbo actuator is now goosed from the oil. I suspected the second turbo wasn't working so booted it on the motorway today and got restricted performance. And the following errors. So it's not well!!
Might as well keep updating this now.
P20253 Member Since: 17 Mar 2024 Location: Manchester Posts: 1 ![]() ![]() ![]() |
Hi James, any updates on this? Did you get it resolved? |
Sorry I just saw this whilst looking for something else. Yes long story short, everything above was true really - the loom recall had not actually been done, unfortunately the oil damaged the turbo actuator (most annoyingly so that it did actually work, but it woudl just create a spurious fault code when the 2nd turbo was activated).
