Home > Maintenance & Mods (L322) > aux heater help
dazk2001
United Kingdom 2008 Range Rover Vogue SE TDV8 Stornoway Grey
aux heater help
ok so thought i would try the aux heater as its getting colder in the mornings
set the timer for 6 am checked the car at 6.20 nothing
tried key in position on touch manual on the screen button goes green then orange
can hear a fan or motor running under the battery but cuts out after a min or so
what could be the issue where to start diagnostics
thanks 2008 Range Rover 3.6 TDV8 Vogue SE
Post #673472 16th Sep 2023 6:45am
KF
Finland 2007 Range Rover Vogue TDV8 Stornoway Grey
Best way to start is to run diagnostics for the heater, Webasto service or someone with a proper tool. Might be a fuel pump, glow plug, bad circuitboard or something else, only guessing until diagnostics. -07 Stornoway Gray TDV8
Post #673475 16th Sep 2023 7:10am
dazk2001
would that be i iid tool or webasto diag tool thanks 2008 Range Rover 3.6 TDV8 Vogue SE
Post #673479 16th Sep 2023 7:45am
Full-fat-Lance
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Orkney Grey
Sure I’ve read on here before it’ll only come on when it’s actually cold enough. Vaguely remember a figure of 5c or lower.
Post #673503 16th Sep 2023 1:27pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
There’s loads on here about them; most often it’s insufficient battery voltage level that causes the Aux heater to stop. A simple check is to fully charge the main battery and then use the manual touch screen method to start the Aux heater. You should hear the fuel pump ticking under the rear seats and the main cabin fans start up. Even then I think the ambient temperature has to be low enough for it to fire up. TDV8 4.4 2012
Post #673510 16th Sep 2023 3:47pm
KF
Webasto tool. -07 Stornoway Gray TDV8
Post #673511 16th Sep 2023 3:47pm
