![]() | Home > Technical (L322) > Fuel filter. |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
I change every 3 year due low milage, 10 000km/year. |
pjw888 Member Since: 04 May 2023 Location: Dumfries Posts: 31 ![]() ![]() ![]() |
Hi, doing that mileage I'd change every couple of years. I'm a low mileage user but do mine every two years to be safe. I use genuine and or OE spec only. I've had some bad experience with some but not all Britpart parts so choose more carefully now. |
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 450 ![]() ![]() ![]() |
Thanks, guessed that was the case but wanted to check.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
I personally consider Febi far superior to Britpart. Most car parts may be similar in quality of design and materials used (even including genuine), but the quality control I would say differs vastly.
Good to know.
I doubt you'll ever need to change the glow plugs - theyll most likely exceed the life of the car, so only change if there's a fault. Key things with the L322 diesels are keeping on top of oil changed. A strict 5,000-7,500 mile interval. 2015 Range Rover Autobiography 4.4 SDV8 |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
I change all filters annually. Generally use Mahle ones from Advanced Factors.
