![]() | Home > Maintenance & Mods (L322) > Squeal from cold start only, goes away until next cold start |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
If it's on that side, have you reached under and put your hand on the compressor tank to feel for any vibration? I wonder if it is something to do with the air suspension (there's valves behind the wheel arch).
TorontoDee Member Since: 27 Sep 2022 Location: Toronto Posts: 76 ![]() ![]() ![]() |
Worth a shot investigating, thanks. 2012 Supercharged L322 |
It could also be the torque converter or transmission fluid (if you know when it was last changed). 2015 Range Rover Autobiography 4.4 SDV8 |
Transmission and Diffs (both) done 6 months ago. Indy has looked at the starter and TC as well.
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 223 ![]() ![]() ![]() |
Mine has started doing exactly the same thing today- drove me insane 2009 (2010 MY) 5.0 Supercharged Autobiography
