Home > Technical (L322) > C1A08-1C, pressure sensor supply voltage out of range |
robertcope Member Since: 12 Aug 2023 Location: Houston, TX Posts: 4 |
This morning, I decided to try and simply the circuit, so to speak. I started by disconnecting the height sensors, which are the other sensors receiving a 5V signal. No change with them disconnected. Of course, if there was a short there, maybe that isn't surprising.
9th Sep 2023 4:15pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Check for corroded fuses, I've had more than a few issues with EAS due to this. Open circuit voltages can be misleading as the control module will recognise something is disconnected, get a decent set of backprobe pins and an accurate voltmeter. |
9th Sep 2023 6:26pm |
I'll take a look. But every other signal, function coming from the EAS module is working fine. Everything I measure says that this circuit is fine, too. I've checked continuity of the wires, checked them for shorts/grounds, etc. Everything is nominal according to my measurements. I've added jumper wires to ground, for the 5V line, etc. I've unplugged the connector from the ECU, it still reads .980V. I grounded the 5V line from the ECU and it did move, to 0.990V. I'm stumped.
9th Sep 2023 6:28pm |
