![]() | Home > Technical (L322) > 5.0 supercharged smoking |
alh Member Since: 19 Oct 2017 Location: Fife Posts: 23 ![]() ![]() ![]() |
I'm away from homje at the moment all I know it's done lessthan 50k, it came complete with every thing g on it
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3201 ![]() ![]() ![]() |
That’s handy having a friendly mechanic to do the work for you |
Looks like the old engine is a timing chain issue as all 4 cylinders are apparently down. Will get to checking it once car is up and running. Car will be spoiled new Brembo calipers,and brakes, upgrade engine pSC pulley kit and ECU mapped potential 650bhp, trying to get a Gurrelia exhaust from Holland will Sound like SVR at the press of a button. 22" Overfinch Wheels with Perlli Verde tyres, black Gloss front grill, new front and back LED lights and a new Android Head unit for infotainment and limited control. Its taking a it of time ut it will e worth it to me.It will.
Each to their own but that noise spoils the Range Rover for me.
I like the vroom when you want it and its only at the touch of a button. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8540 ![]() ![]() ![]() |
If you re-pully and map it just be careful with the gearbox, it can't take too much over the standard torque, get the oil changed.... Avoid Grand Prix starts and don't floor it unless all the wheels are pointing in the same direction... |
William97841 Member Since: 18 Jan 2015 Location: Essex Posts: 141 ![]() ![]() ![]() |
Hi mate the one I looked at was bluey/black and had it looked like joker on the number plate,is that the one you bought?
That was the one lookslike something went wrong with one of the chain. It was a shopfy job lots of bolts missing and bumper held on with tie wraps. Hopefully the old engine can be fixed and sold on |
Got upgrade gearbox filter ca
Upgrade gearbox filter |
Ahhh sorry to hear that mate.hopefully you can get there sorted. When I put my iid tool on it about 28 faults come up and one of the main faults was timing codes and cylinders 1-8. So I knew something was wrong with the chains but the car was perfect. |
I took chance but got a 50K replacement complete engine for £4700. A faulty engine is going for about £2800 that's the deposit on a recondition exchange that can be repaired plus about a min of £6500 for the recondition Unit. If they tell you that your old engine is goosed you loose your deposit.
