Home > Maintenance & Mods (L322) > Can I do anything to raise this towbar?
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
I have the towbar below. Its detachable and looks like it has a square receptacle that the thing slots into on the main frame.
My issue is that the towball is a little low for my new trailer. Can I replace the detachable bit with something to make it higher?
Thanks!
[/img]
Post #672717 5th Sep 2023 7:53am
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Use the multi-height attachment that fits into the same square receiver on the main towbar frame.
Come up on eBay quite often.
Part no. is VUB000720
 Jonathan
2007 Defender 90 XS Hardtop
Post #672719 5th Sep 2023 8:26am
Weegie
The option you have is to replace the quick release part for a farmers hitch with the drop plate. Need to find one.
AFAIK its the only option. Stand to be corrected.
Edit: As above John
GAP iiD BT
Post #672720 5th Sep 2023 8:27am
philip1972
Brilliant, thank you.
Post #672721 5th Sep 2023 8:35am
There are 3 versions of that - a pin (as shown), a bolt - and a final one where the inserted bit is half threaded and a bolt.
The pin makes it quick release, but can be rattly. The half threaded is more fixed and quieter. Just the bolt is the worst of both.
I'm trying to remember whether it is actually any higher though.... not sure whether the middle or top holes are the same height as the quick release one....... Worst case, once you have it, you can buy a replacement tow ball that has extra height - like this one
Post #672722 5th Sep 2023 9:00am
Weegie
This thread shows an anti rattle device for the farmers hitch:
https://www.fullfatrr.com/forum/post670078.html#67007
First post.
I had the same thing for mine and it worked very well. John
GAP iiD BT
Post #672727 5th Sep 2023 10:01am
