Home > Maintenance & Mods (L405) > Cost for new brake discs and pads
Jay Porsche
United Kingdom 2017 Range Rover Vogue SE TDV6 Fuji White
Hi All,
My car is coming due for service and there is a pronounced lip on the brake discs so I think they will need doing.
Does anyone know what the target price should be for replacement disc and pads?
I am taking it to my local Indy but I don't have to get them to do the work.
I have had decent service from my local Halfords Autocentres for my wife's BMW so I'm not opposed to using them for it.
Thanks in advance.
Post #672672 4th Sep 2023 10:11am
I can't remember the cost, but when I had mine done, I got the genuine parts from Duckworth's (site sponsor) and had my local Indy fit them. Worth giving Robin a call to ask
https://www.fullfatrr.com/forum/duckworth-parts-vf24.html
Post #672673 4th Sep 2023 10:14am
Last time I bought some discs, Robin at Duckworths was cheaper than anyone else... Thumbs Up Pete
Post #672678 4th Sep 2023 10:43am
RRV8SC
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Land Rover online service booking around £1400.
I’ve just had mine all replaced local independent, Pagid pads and discs £1100
Post #673145 11th Sep 2023 6:08pm
V8Russ
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Had my rear discs and pads replaced by my mobile mechanic. £425, labour, parts and vat.
Post #673147 11th Sep 2023 6:35pm
Halfords? What parts do they supply? Are they trustworthy on such a car?
Post #673172 12th Sep 2023 12:21am
RRV8SC
From my limited experience, windscreen repairs and new batteries, they blow a bit hot & cold. All of the staff seem very good, but their back office left a bit to be desired.
Post #673195 12th Sep 2023 11:14am
Gremlin500
Have a go yourself! It’s a nuts and bolts job, not much harder than changing a wheel.
I got these KINETIX drilled/ventilated/plated discs for £588.00 last year (full set F&R, with pads/springs/pins and wear wires), price is £71 more now, but excellent quality:
https://www.azcarparts.co.uk/products/for-...mbo-pads-1
(My TDV6 has V8 brakes, so you need to search for the correct item).
Delivered very quickly in 2-3 days. Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #673199 12th Sep 2023 11:50am
caymanblack
I went to do my front discs and pads today do you think I could undo those caliper bolts, no way just too tight so will have to ask my local garage if they would slacken them off a bit for me. Censored off as the back ones were no problem at all. overfinch modified
Post #676145 22nd Oct 2023 5:12pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
It's an easy job. But you do have to put the handbrake into service mode.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #676146 22nd Oct 2023 5:41pm
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
I bought Brembo discs and pads for my L405 SDV8 and it wasn't cheap, but it wasn't expensive either.
Discs
09.A773.11
09.B504.11
Pads
P 44 023
P 44 021
Cost 18 months ago was £530.
There is a YouTube video available showing the disc and pad change including how to manually put the park brake into service mode.
Post #676152 22nd Oct 2023 6:50pm
