![]() | Home > Technical (L405) > Gearbox Heat Shield/bash plate bolts. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Remove the silver cover and inspect the black cage above for cracks, as that's what causes noise/resonance issues sir... |
BurnsideDalesbreds Member Since: 01 May 2023 Location: Deepest Aberdeenshire Posts: 14 ![]() ![]() ![]() |
Thanks Craig, what is the black cage called? I’ve recently had the gearbox serviced, it was only after that when the vibration started. Will drop the plate and have a look.
It’s just the mounting frame for the heat shield sir… Not 100% sure of its exact name… |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8368 ![]() ![]() ![]() |
Mines called Steve............
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1153 ![]() ![]() ![]() |
