![]() | Home > Technical (L322) > Tow Bar Help Please |
beemer5711 Member Since: 01 Aug 2022 Location: Wales Posts: 72 ![]() ![]() |
Thanks. When you say software will ask what type of trailer is connected, is that on the dash? |
Thanks again |
Arbuckle Member Since: 11 Nov 2018 Location: Northants Posts: 78 ![]() ![]() ![]() |
Thanks. When you say software will ask what type of trailer is connected, is that on the dash?[/quote]
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
I think that only applies if trailer assist is fitted / activated. My infotainment screen doesn't display anything when connected, just the trailer icon on the driver display. 2015 Range Rover Autobiography 4.4 SDV8 |
Can tow assist be turned on on any car?
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 100 ![]() ![]() ![]() |
If replacing the whole thing try PF jones and go for the westfalia one (2 options one with detachable and one fixedish ) there wiring kit is also plug n play on a 4.4tdv8 with no programming required unless you want the fog lights deactivating (2x7 pin anyway), re fitting (I've done a couple) its bumper off and nuts n bolts , a bit awkward round exhaust but not that bad . I use the one with the square hole receiver type hitch that slides in and is locked by a big pin but have put the full detachable hitch (like the D3/4type swan neck) on someone else car for them , dragged caravan's and car transporter trailers round for 7ish years now with no issues . (just watch your speed as it's very easy to hit 80/90 whilst overtaking with van on back ). |
Answer 2 regarding electrics , my caravan has normal bulbs and when connected bottom left of main dash has a little trailer logo in green that flashes when indicating , it also works fine when I have Thule bike rack on and that is full led , don't know if Thule fit load resistors though . |
Thanks to everyone on here, your help has been great.
TowBar2024 Member Since: 06 Dec 2024 Location: Belfast Posts: 1 ![]() ![]() |
Hi, this is great Info... i have the exact same receiver on my 2016 Audi Avant. but i cant find out what swan neck fits this. can you help? there is loads on ebay to pick from! Thanks
winco Member Since: 12 Feb 2024 Location: Dorset Posts: 40 ![]() ![]() |
Just a note on dashboard indication; I have a 2013 Jaguar XF Sportbrake, and I fitted my own towbar sourced from PF Jones. Towbar was a detachable Witter and the electrics were Brink (but many other brands had the same instruction leaflet). I coded the electrics in using SDD.
