![]() | Home > Maintenance & Mods (L322) > Battery Drain |
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 ![]() ![]() ![]() |
Unless the mobile electrician "knows" these cars then probably not.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1390 ![]() ![]() ![]() |
My 2012 WM drained its battery completely on two occasions, once it was a locking software fault, the other time I think a fuel burning heater software fault. In each case sorted under warranty. The dealer ran a diagnostic check to locate the fault and then sorted the software. The battery needed to be fully charged to be tested as to whether it would still work properly after full discharge. The first time it would not and had to be replaced (under warranty), the second time it was OK. The battery apparently needs to be fully charged before it can be checked.
paulwlincs Member Since: 07 Oct 2019 Location: Lincoln Posts: 44 ![]() ![]() ![]() |
So yesterday i pulled all the fuses , reconnected a fully charged battery and it went straight to 7v . The original AGM battery is toast at 2.9v and it refuses to charge .
