Home > Technical (L405) > I bricked my car....2020 L405 |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
Have you tried restarting the instrument cluster update?
29th Aug 2023 2:41am |
steve56 Member Since: 13 Jun 2020 Location: colorado Posts: 13 |
Everything was fine with downloading new firmware for all 3 modules.
29th Aug 2023 2:47am |
I would disconnect the instrument cluster then see if any module can communicate. In various earlier vehicles the instrument cluster is connected to both the HS and MS canbus so could conceivably lock out both. |
29th Aug 2023 2:58am |
Thank you Graeme! I’ll have my tech do that!
29th Aug 2023 3:01am |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
The gateway will be stuck in bootloader mode, don't worry about the IPK until you get the gateway to communicate. Worst case is a new gateway module. |
29th Aug 2023 6:17am |
Sounds cheaper than a new IPK! |
29th Aug 2023 7:50am |
My dealer is a god send and very helpful. They are following procedures that you guys suggested, so thank you so much.
31st Aug 2023 6:23am |
