Home > Maintenance & Mods (L405) > Six Pot Callipers |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
My front callipers are about a year old... it looks like they have melted.... only looks like, they haven't really but the finish seems to have suffered.... anyone else had this, could it be TFR used by car washes...
27th Aug 2023 10:13pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Yep, it'll be the 'wheel cleaner' mine have bands across them where the spokes have masked the calipers, I'm planning on using https://www.amazon.co.uk/TechniQ-Thunder-C...B07QXSN7KK with a replacement hold-down kit. I also use Sonax wheel cleaner which doesn't attack anything and everything else...
27th Aug 2023 10:29pm |
Just had this delivered, used it before and like the finish, should look near original...
28th Aug 2023 10:16am |
What did you clean them with prior to painting? I've only ever sent them away for refurb with someone else paying, I'd imagine a heady mix of brake cleaner brass wire brush & Scotchbrite? |
28th Aug 2023 2:19pm |
I've just used neat TFR in the past, a good rinse then brake and clutch cleaner... red scotchbrite and a very light coat of acid etch primer, I then paint the faces in high temp silver, use a cut vinyl logo on top, coat the whole thing with the Thunder grey, remove the sticker to reveal the logo in silver the clear coat the lot with high temp... seems to last a good long time....
28th Aug 2023 3:51pm |
Hmmm.... I might relieve our wishy-washies of a litre or so of wheel cleaner, that should 'bite' the brake dust a bit better than TFR. I'm not sure about the logos - but your way of masking is much better than leaving the stickers in place, which is what most do, that and 'colour coded brake pads'!
28th Aug 2023 4:17pm |
I get the TFR from a local cleaning place, it's supposed to be diluted 100:1 to clean HGV chassis...
28th Aug 2023 7:48pm |
From what I remember, TFR is acidic, wheel cleaner is alkaline (possibly the other way around) one of them lifts burned-on brake dust better than the other but either will do the job in it's 'diluted less than specified' form. The wishy-washies at work know not to use wheel cleaner on my car, usually because I've already sprayed Sonax on them - which turns the brake dust blood red! the TFR is sufficiently diluted to have minimal effect upon anything, least of all the 'TF'.... |
28th Aug 2023 8:04pm |
It cleans well but yeah, dodgy stuff, I think it's alkali, I used it neat on some old filthy wheels that were beyond saving, left it on for 10 mins and it etched the surface and the wheels ended up matt finish..
28th Aug 2023 9:38pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Im Loving the Union Jack look right now Peter...
28th Aug 2023 11:13pm |
JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 180 |
The standard finish looks like the cheaper anodised finish some OEMs use. On my L322 these had turned literally white from years of harsh chemicals.
29th Aug 2023 6:50am |
Craig, shame to put the wheels on and mask some of the callipers, they look ace....
29th Aug 2023 8:14am |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1130 |
Those Aston Callipers look great! overfinch modified |
29th Aug 2023 8:51am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
they do indeed.....but not on a range rover ... - .- -.
29th Aug 2023 9:54am |
