Home > Technical (L322) > More lights than a Christmas tree
E18RLY
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Got in the car this morning to find air susp inactive light on as I need a compressor Sad but then the hdc inactive light on, abs light, a orange (!) light, low range gear box light flashing, then when driving it kept flashing select neutral and tans box neutral Sad someone please tell me it's just a compressor confusing everythig???
Post #67196 6th Jun 2011 9:13am
sounds likely ...most of the ecu's do 'talk' to each other so maybe thats why you are getting the errors..
have you tried dis-connecting the battery to see if the ecu's settle down...
Post #67199 6th Jun 2011 9:25am
E18RLY
Can I just disconnect battery then reconnect and drive off no reprogramming or imobilzer problems or anything?
Post #67200 6th Jun 2011 9:29am
wait 10 minutes before disconnecting the battery [key out of ignition]
wait 20 minutes before re-connecting
when battery re-connected , turn steering wheel fully to the left and the fully to the right.
Post #67203 6th Jun 2011 9:36am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
One more small point; what state is the battery in?
If it's a bit leggy then that could also cause plenty of problems.
Post #67220 6th Jun 2011 11:24am
E18RLY
Got told it had a new battery just befor a got it. The battery looks new but after a week the battery went dead after having the radio on for half an hour
Post #67232 6th Jun 2011 2:01pm
your problems could relate to a dodgy or underpowered battery...you should have a 110amphr ,920 crank, battery on the td6..
Post #67235 6th Jun 2011 2:05pm
E18RLY
It's goin back next week al get them to check it out thanks very much for the help and advice Smile
Post #67308 6th Jun 2011 6:53pm
sportin
United States 2006 Range Rover HSE 4.4 V8 Java Black
A lot of short trips may not charge the battery sufficiently, considering that the compressor just ran..etc....if you keep the headlights set to auto turn on, and they illuminate as you start the vehicle, that could cause the available vols/amps to be lower than the required minimum amount needed, to initially get the systems booted up properly. And if you left the climate control on........the battery will be powering the fan to. Lets not forget that the steering wheel tilt is probably adjusting at the same time too. So........make sure everything is off before attempting to start, turn key to position one until the steering wheel is done adjusting, then finally start her up. If you want to be really cautious..........wait for the logo splash screen to turn off. By that time power has gone through the entire system loop. 2006 RR 4.4 HSE
2008 Audi A6
Post #70438 29th Jun 2011 4:39am
