Home > Maintenance & Mods (L322) > Rear callipers seized? |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1258 |
When I put on my new ones I could push them in with my fingers when NOT connected to the hydraulics.
21st Aug 2023 9:40pm |
NDT Member Since: 03 Apr 2018 Location: Bedfordshire Posts: 85 |
Thanks Kevin, I’ll give that a go. |
21st Aug 2023 9:49pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
Sounds like they are seized (not uncommon) 2012 TDV8 Vogue (L322) |
21st Aug 2023 10:33pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 |
This may sound stupid, but are you using a caliper rewind tool (available from any car parts store / Amazon / ebay)?
21st Aug 2023 11:54pm |
You can feel the piston 'give' a little with just both thumbs even if it doesn't move far. A block of wood in the jaws with just enough room for a screwdriver will show plenty of movement. A seized piston is rock solid. 2012 TDV8 Vogue (L322) |
22nd Aug 2023 6:54am |
Thanks all.
22nd Aug 2023 9:03am |
Maybe worth removing the pistons, replacing the seals and cleaning up any corrosion on the pistons and bores nr the tips as if you are putting in new disks and pads and you have to retract the pistons this is when the can seize. 2012 TDV8 Vogue (L322) |
22nd Aug 2023 9:11am |
Thanks all for the helpful suggestions.
26th Aug 2023 9:20am |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2269 |
Enjoy the holiday |
26th Aug 2023 9:24am |
