![]() | Home > Technical (L322) > Air suspension ecu (RQT500181) terminals for rear right |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2650 ![]() ![]() |
The rear harness is in the black connector that is at an end. The other end is grey (front harness).
kirk05 Member Since: 25 Jul 2018 Location: Aberdeenshire Posts: 14 ![]() ![]() ![]() |
Brilliant many thanks GraemeS |
On some models the connector is white but mostly black and always the end connector. I make kits that use a short extension harness that fits between the front and rear harness connectors and the ecu that fits L322 MY07-12, D3, D4 and L320 RRS which all use the same suspension ecu. The L405, L494, L462 and L663 all use another ecu that uses a different set of connectors for which I use a different extension harness. |
I snipped off those 3 at the ecu and the sensor and ran a 3 wires between them and it worked! cheers...will be planning permanent fix next |
