![]() | Home > Technical (L322) > Starting issues |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2651 ![]() ![]() |
The contacts in the solenoid on the starter motor become burnt due to inadequate wiring between the starter relay and the solenoid, initially requiring multiple start attempts but eventually the starter fails to run. Your description suggests this issue rather then something wrong with the key. |
raulj Member Since: 09 Jun 2023 Location: Tartu Posts: 3 ![]() ![]() ![]() |
There should be a warning displayed when key is not found. If no warnings and no crank then probably something other than key problem. |
