Home > Technical (L405) > wheel bearing replacement
sla76
Poland 2010 Range Rover Vogue SE TDV8 Bournville
Hello forum users,
I am asking for information on what the cost of replacing the rear left wheel bearing may be.?
Do you need special pullers for this ?
Thank you in advance for a quick answer.
p.s the symptom is a strong buzzing in the speed range from 60 km/h to over 160 km/h
Regards. RR L322 3.6 TDV8 2010
RR L322 4.4M62 2004 -sold
Jeep Grand Cherokee 4,7 HO-sold
Foxwell 510 PRO
Post #671392 17th Aug 2023 2:58pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
i suspect if it is like other recent JLR vehicles the bearing is encased in a hub and are not normally hugely expensive or require much in the way of specialist tools. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #671418 17th Aug 2023 7:55pm
sla76
Thanks for the response.
Would someone from the forum be so kind and check in TOPIX ?
thanks in advance
getting ready for work over the weekend RR L322 3.6 TDV8 2010
Foxwell 510 PRO
Post #671465 18th Aug 2023 12:22pm
have a look in the workshop manual..
download from our wiki.. ... - .- -.
Post #671469 18th Aug 2023 1:14pm
TPhipps
United Kingdom 2016 Range Rover Vogue SE TDV6 Santorini Black
I had OSR bearing replaced under warranty by local main dealer c£115. Bearings are encased in hub, and was less than a half day fix for them.
Post #671472 18th Aug 2023 2:57pm
TPhipps
Also Just remembered.........don’t forget to have a 4 wheel alignment check after you have replaced the bearing. Mine was pulling slightly to the left after the work had been completed.
Post #671473 18th Aug 2023 3:02pm
