![]() | Home > Wheels & Tyres > Winter set up.. AT vs winter tyre vs all season |
Ennoch Member Since: 26 Dec 2015 Location: Scotland Posts: 109 ![]() |
Only on an Evoque which is about half the weight of an L322. That said, after 5k miles they still look brand new, and the about the same can be said for the ones on my mate's L322 that I'm about to buy. They've gone further and are a little more worn but not horrendously so. I can't imagine me ever getting more than 20k out of a set of tyres unless they start with an inch of tread though, no matter what they are! JayGee's experience is probably more relevant than mine, given I'm getting about 8k out of a set of rear tyres on an AWD BMW estate... All Season tyres are certainly made of harder rubber than UHP tyres because they're not aimed at ultimate performance, and neither are they made from the super soft silica heavy winter compounds, so 30-40k miles seems pretty reasonable you're not honing it. That's based on previous 4x4's and comparing my ability to kill tyres to the average human's. They certainly won't last as long as an all terrain all things being equal as the AT starts with at least 50% more tread, but you're not going to wear them out in 10k. |
Byg Nyge Member Since: 31 Dec 2022 Location: Newcastle Upon Tyne Posts: 31 ![]() ![]() ![]() |
Gotta say in 50 years of driving I have never changed tyres for winter, and I've driven in some pretty horrendous weather in those years. Never had a problem. Maybe I was just lucky? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7969 ![]() ![]() ![]() |
Depends how you define 'problem' - every winter I get stuck behind people crawling along not having a problem - they cause me one though.
Just like most people won't ever have a 'problem' if they never wear a seatbelt or deactivate their airbags. 2012 TDV8 Vogue (L322) |
I always used quality tyres tho', no remoulds, no part-worn. Changed @ 4mm tread depth. |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
I run winters Goodyear ultra grip from November to April and Michel pilot sport summers although I am trying Pirellis this summer just to see how they go so far 3k miles and ok but not as grippy in dry or wet as Michelins so will probably put them on the back up |
I run winters Goodyear ultra grip from November to April and Michel pilot sport summers although I am trying Pirellis this summer just to see how they go so far 3k miles and ok but not as grippy in dry or wet as Michelins so will probably put them on the back up which only does local stuff |
My wife always says I keep repeating myself |
Absolutely. With winters on I can drive quite happily at 40-50 on deep snow covered A-roads and do an emergency stop without the ABS cutting in if I need to. I've also driven over the Bealach na Ba in snow covered ice with no dramas while others struggle to get moving on flat ground nearby. There's also the argument that just because someone didn't get stuck 50 years ago doesn't mean they wouldn't get stuck now given the rather dramatic changes in what constitutes a 'normal' tyre on a car. Plain and simply if you have more than a dusting of snow on the road and modern summer tyres (fresh from the packet or worn), you just aren't going to be going anywhere fast, and I've got more than enough miles to cover in winter that I want to be covering it at as close to normal speed as is reasonable rather than driving white knuckled at 10mph. Winters turn arduous conditions into fun conditions that allow you to simply drive around everyone else like they're stood still. I've had that many, many times up here in the Highlands, and no doubt I'll have many, many more times where I'll do the same in the future too. It's funny that many a time I've driven from the croft down to Torridon with up to 6" snow on the road at 4/5am to go climbing and arrived faster than I can manage in summer with the average speed and ability of the tourist traffic on the road. I'm sure those guys all think they're great drivers too...as I'm sure did the dozen plus drivers I've pulled out of ditches in the snow over the last five or so years. By no means am I saying that everyone should fit winters, but the 'oh, I've never been stuck so that means nobody will get stuck' is a nonsense and got old a long time ago. |
Also worth noting its not so much the getting moving on ice its the stopping that makes winter tyres a must plus why not give yourself the best chance possible of arriving safe and well |
MikeyB48 Member Since: 10 Jan 2023 Location: UK Posts: 10 ![]() ![]() |
Yeah full winter tyres are a revelation. I was in the high north of Norway for an extended period over the winter just gone and was astounded at how effective full winter tyres are.
NDT Member Since: 03 Apr 2018 Location: Bedfordshire Posts: 85 ![]() ![]() ![]() |
Lot of good points on this thread.
I guess it depends on what you define as light off roading..... |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1586 ![]() ![]() ![]() |
A very good point! ![]() I for one couldn’t be *rsed ![]() ![]() |
