![]() | Home > Technical (L322) > Front Seat Removal, Dissassembly and Heated Seat Repair |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 783 ![]() ![]() ![]() |
interesting
andyrosehome Member Since: 06 Jan 2018 Location: South Wales Posts: 14 ![]() ![]() ![]() |
No, the only wires accessible under that leather seat flap are the heated seat wires. However, once the elasticated clips are undone and the leather flap lifted out of the way, you can access the 2 torx screws that secure the bottom of the seat back cover and you will then be able to remove the seat back cover completely while the seat is still bolted into the car. That exposes much more and is where the airbag wires should be. I know the passenger seat has an occupancy sensor which inhibits power to the heated seat if unoccupied and I assume the airbag system would use the same sensor to avoid duplication costs. If I recall correctly it is under the seat squab so you would need to unbolt the seat and tip it back to access it which isn't too difficult. Just remember to disconnect the battery before unplugging anything especially airbag related items. |
my air bag light is on and the gap tool says it is the occupancy sensor, i replaced the sensor with a second hand one which the man said was ok before he wrecked the car but it still on.
Hmmmnnn. I'm not sure to be honest. if you have the old switch can you test it with a meter? and then if it is bad maybe test the replacement switch? I assume you cleared all the faults with a scan tool once you replaced the switch? |
yes i did clear all the faults but they came back again
if you still have the old switch, post a couple of photos of it and the attached wires or connector plug and I'll try and help you. |
