Home > Maintenance & Mods (L322) > Air Suspension issue.
Seftona3103
United Kingdom 2010 Range Rover Vogue SE 4.4 V8 Baltic Blue
I have a 2010 L322 4.4 TDV8 Vogue Se.
This is weekend I took the vehicle green laning and unfortunately my Front Passenger suspension had a leak causing the compressor to overheat and the complete suspension dropping to bump position showing a 30 mph limited.
Not something you need while doing strata florida in Wales.
Anyhow the question is should I replace all sir bags as preventative maintenance or is it OK just yo change the faulty one?
Any advice would be appreciated
Post #671127 13th Aug 2023 10:15pm
GraemeS
Australia
You could just replace the bag and possibly the other side too as its condition won't be much better but if the shocks are well-worn then best to replace both assemblies, not just 1 side. The rear bags don't have the same issue as the fronts but if fitting new front asemblies then you'll most likely feel that the rear shocks also need replacing.
Post #671130 14th Aug 2023 1:08am
JayGee
Are you sure it's the air spring as it could be the air hose, joint or valve block that's leaking. 2012 TDV8 Vogue (L322)
Post #671134 14th Aug 2023 6:08am
Seftona3103
No not really sure where it is leaking. All i know is that you can hear air coming out worse when on off road height.
How can I check if its the bag or hose?
Post #671146 14th Aug 2023 9:06am
Seftona3103
Thanks for the info. If I need to replace I will replace both fronts first and see how it is.
Post #671147 14th Aug 2023 9:08am
Seftona3103
Just spoke to one of the guys who said he could feel the air coming out the back so he think its the Air spring.
Post #671151 14th Aug 2023 9:34am
GraemeS
Australia
Sprayed soapy water will show leaks from the airsprinng.
Post #671153 14th Aug 2023 9:41am
