Home > Maintenance & Mods (L405) > Gearbox Replace? |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2491 |
Are you sure that your restricted performance isn't caused by leaking donut hoses? Can you see oily areas on the manifolds that hasn't come from 1 or more of the 4 hoses?
13th Aug 2023 11:34am |
Iain Member Since: 06 Nov 2021 Location: Kent Posts: 3 |
Manifold is a done deal - I can see the crack on the RH (I'm doing both at the same time)
13th Aug 2023 12:14pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8255 |
You need another box with the exact same part number, someone on here tried with one with a different last digit IIRC and although it was the same physical box it was not suitable...
13th Aug 2023 12:33pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1194 |
Would it be worth going to a specialist that you trust to just get their diagnosis on the subject / fault, then go from there, just in case they found something that could be rectified ? and save you time and money.
13th Aug 2023 2:59pm |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1141 |
I have read good reviews from this place?
13th Aug 2023 3:05pm |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 135 |
Before spending thousands on a new box it may be varnish build up in the galleries and solenoids. You could try adding 1/2l of a strong solvent like SeaFoam TT16 (trans tune). I do have some on sale on eBay as do other sellers and the feedback I have had for this product has been good.
14th Aug 2023 11:02am |
AnotherMutley Member Since: 16 Jan 2017 Location: Kent Posts: 400 |
Depending on where you are in Kent, might be worth getting a second opinion on the driveline from QP Online at Maidstone. |
14th Aug 2023 11:11am |
Thanks for replies.
15th Aug 2023 12:59pm |
