Home > Technical (L322) > Lower tailgate
Dazzab1972
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
Lower tailgate
Hi
I need some help with the following.
Has anybody had an issue where there is no power going to one side (right in my case) of the latch on the rear lower tailgate?
I have removed the right hand side latch and plugged it into the left hand side and it works, so it’s not the latch.
Is there a fuse?
2012 Westminster
Thanks
Darren
Post #670897 10th Aug 2023 3:28pm
garyRR
Both the left and right are fed from the same fuse.
Have you tested the multiplug to the latch with a multimeter to check there's a voltage applied when the release button is pressed and again at the tailgate release button end?
The next point to check would be the tailgate harness multiplug near the spare wheel. Pins 3 and 4 are the ones for the right hand latch. Cables are yellow and black (YB) and red and grey (RS).
Next point would be this connector in the passenger fuse box:
Then you can isolate between where the fault is. If the latch works, it is more likely than not a damaged cable or bad contact. 2015 Range Rover Autobiography 4.4 SDV8
Post #670937 10th Aug 2023 10:27pm
As Gary said... Thumbs Up Thumbs Up Thumbs Up
Post #670941 11th Aug 2023 12:47am
Dazzab1972
Thank you Gary.
Post #670947 11th Aug 2023 6:26am
