Incontinent suspension valve? | |
 | Click image to enlarge |
Hi guys,
strange stuff is going on in my SC 5.0 (MY 2010): when I leave the suspension alone (meaning neither let it rise nor drop) it´s holding the level wonderfully over weeks - nothing happens. Anytime I use it, I get a warning afterwards that only normal height is available.
I was wandering, if that might be the compressor and checked the pressure on the gallery and the temperature of the compressor during a drop-rise session: nothing eye-catching.
But then I recorded the suspension valve behaviour during a drive after I have lowered it to normal height - at the attached screenshot you can see, that the rear right valve opens after around 60 seconds and closes directly again.
What do you think this might be? Does it suggest a problem with the valve block or maybe the height ensor in this wheel? Or is it possibly something else?
Cheers
