Home > Technical (L322) > Torque converters
Tiprat
Torque converters
Good morning guru's, just wondering if the torque converter on a 2007 and a 2002 Range rover are the same. Just in case I have to swap mine.
I know of a good one on a 2002 RR that is sorned off road.
Regards
Tiprat Borrowed Grey 2002 3d 204k for a year
Now own a 2007 Java black Vogue SE 3.6TDV8 160k
Post #670613 7th Aug 2023 9:10am
AnotherMutley
No, different boxes.
TDV8 is a ZF, the 2002 will be either a GM or a ZF depending on engine, but either way they're not interchangeable.
Post #670648 7th Aug 2023 2:57pm
If you do find one for your box the labour involved in changing it is not really worth going second hand, could be a whole host of issues.... Pete
Post #670652 7th Aug 2023 4:18pm
RRPhil
The 3.6 TDV8 uses the Y94 torque converter, ZF part no. 4168 027 074
The Land Rover part no. is TQB500210 or LR048684
Phil
Post #670655 7th Aug 2023 4:50pm
Tiprat
Thank you for all your advice and help guys, the only reason I asked about the 2002 model was because I knew that one had already been reconditioned. Borrowed Grey 2002 3d 204k for a year
Post #670665 7th Aug 2023 5:49pm
