Home > Wheels & Tyres > L460 alloys on L405
Overfinch JR
L460 alloys on L405
L460 alloys on L405
Has anybody fitted wheels off the new L460 to their L405 ? I’m struggling finding the right wheel nuts as they are different- any ideas ?
Post #660416 26th Mar 2023 4:30pm
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
It is possible. I have just fitted L460 wheels and tyres to my L405.
They work really well and the Michelin Primacy All Season in 275/50R21 clear without any fouling.
The issue is that the L460’s now use bolts rather than studs/nuts so you need to source some nuts that are M14x1.5 and a 60* taper. In order to achieve safe thread engagement you need to ensure the nuts are fully threaded and don’t have an unthreaded section near the opening. I found nuts for a Ford Transit seem to be the correct fit.
Post #670474 4th Aug 2023 7:18pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Very swish, I haven't seen that style before, they suit the car.
Do they improve ride at all?
Post #670480 4th Aug 2023 10:06pm
Alex1976
Thanks! They are style 5126 alloys. I only came across them by chance on browsing eBay. I particularly like the satin grey finish on them, they feel different to the usual wheels you see but still keeps with my rule of only using genuine LR products.
I had the standard 255/55R20 Pirelli Scorpions before that were original fit with the car, and the new wheels and tyres feel very different (improved). How much that is a size change or how much it is due to tyre manufacturer I am not sure, but so far the Michelins are really great. I like the 275 width but didn’t want low profile so as not to loose the ride comfort and also protection from pot holes etc. so these are perfect.
Post #670487 5th Aug 2023 5:57am
Vogue
They look really well - did the TPMS work
Ok or did it need reprogramming ? 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #670490 5th Aug 2023 6:49am
Alex1976
It’s different TPMS so had to put in some L405 units.
Post #670492 5th Aug 2023 7:08am
kimberultracdp
United States 2017 Range Rover TDV6 Santorini Black
I just installed an set of 2023 RR 21 inch wheels and tires
I was able to reprogram the L460 sensors with no issues
Post #671049 12th Aug 2023 6:40pm
kimberultracdp
The grey wheels look great on your L405
Post #671050 12th Aug 2023 6:41pm
Alex1976
Didn’t know you could reprogram the TPMS! Is this via a GAP IID tool or similar?
Post #671062 12th Aug 2023 9:36pm
kimberultracdp
I used the Matco TPMS tool
Post #671069 13th Aug 2023 1:26am
Alex1976
Thank you! They don’t just look good, I also found out yesterday on my first proper drive (300 mile round trip) that they have massively improved the ride and handling over my old wheels/tyres.
Possibly didn’t need to change the tpms on my wheels then but now I now you can reprogram TPMS Thumbs Up
Post #671072 13th Aug 2023 8:31am
aljo
United Kingdom 2019 Range Rover Vogue SE 2.0 PHEV Santorini Black
Wheels look great 👍
Would fitting these wheels affect warranty / insurance
Would like to go down the same route at some point 👍 Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #671085 13th Aug 2023 11:48am
aljo
Would you be able to point me in the right direction for obtaining the correct wheel nuts in order to fit these please Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #671089 13th Aug 2023 2:13pm
Alex1976
I am now using these:
https://www.trsuk.co.uk/shop/m14-x-1-5-21m...l-nut.html
I originally bought some of these:
https://www.alloywheelnutsandbolts.co.uk/p...hex-set-5/
But I wasn’t happy with the thread engagement. I could only get 8 turns on them, which equates to 12mm of engagement. 14mm is the usual min spec. The new nuts give 13 turns or 19mm engagement.
Post #671095 13th Aug 2023 3:01pm
aljo
Excellent many thanks Alex 👍 Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #671097 13th Aug 2023 3:18pm
