Home > Maintenance & Mods (L322) > Polishing out scratches? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
I was attacked by an ivy bush in the recent windy weather as I made my way home on the A30 the other day. They just fall out of the hedgerow when you least expect it!
4th Jun 2011 8:58am |
Define "Not too deep"
4th Jun 2011 9:10am |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Most surface scratch's can be removed by hand. You probably need a compound to remove the deep scratch's. Meguiars do compounds that break down and give a mirror finish. Have a look at their website. They also do a system for polishing by hand. If not you could also wetland but would need a machine polisher to finish off. |
4th Jun 2011 11:14am |
BRUNBERG Member Since: 13 May 2011 Location: Surrey Posts: 37 |
As above, the fingernail test is the best way to determine scratch depth.
5th Jun 2011 11:34am |
Thanks everyone, the scratches are visual only, no perceptible depth, but I'll give the Meguiars a go... .
6th Jun 2011 5:49pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
I've seen guys in bodyshops use 1500 grade wet and dry with soapy warm water.
7th Jun 2011 8:37am |
