![]() | Home > Technical (L405) > MY19 deployable side steps |
rstoughy Member Since: 17 Dec 2022 Location: Stonehaven Posts: 21 ![]() ![]() ![]() |
Maybe unplugged?
madasmad Member Since: 22 Mar 2020 Location: Cheshire Posts: 85 ![]() ![]() ![]() |
Thanks RStoughy, do you happen to know where I would find the plug please? 2019 Autobiography SDV8 Byron blue/black - current
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1200 ![]() ![]() ![]() |
Hi, Have you checked the fuse's right side rear? The information screen has an on/off button.
Thanks Tinman, I tried the put it in neutral etc but it sadly didn’t work. I found the fuses in the right hand side of the boot but how do you get to them? I have taken a picture.
Hi, it's in the sidewall right side you have to lever it out from the top, mine is number 39, 30amp green.
Hi, have a look here.
Look underneath at the motor end of the step and you should see the big electrical plug sir... Is it plugged in? |
Thanks guys. I will take a look at both of these options. I will let you know how I get on 2019 Autobiography SDV8 Byron blue/black - current
So back from holiday-
