Home > Technical (L322) > replacing BCM
Steve7678
United Kingdom 2006 Range Rover Vogue SE TDV8 Rimini Red
replacing BCM
Does anyone know if I can get a used BCM reprogrammed? I believe I have a BCU that is very sick ( problems with intermittent heavy steering, central locking won't work until 15m after engine shutoff, one-touch window down not working etc etc)
I currently have a 06 TDV8 using YWC500521 which I believe is no longer available brand new so used is my only option. I do have a GAP IID tool and I'm fairly ok with a set of spanners.
I've read that some chip needs to be changed, does anyone have the details?
Post #670318 2nd Aug 2023 4:38pm
ottoknows
Hong Kong 2005 Range Rover Vogue 4.4 V8 Java Black
I have been experiencing these symptoms too.
To rectify the intermittent steering, what I have done is to replace the Power Steering Pump (used) twice. Often, I would have to restart the ignition to get the lighter-normal steering back.
As for the central locking, what I have done is to replace the fuse F15 and F60 with new 5As, and so far it has solved the intermittent non-locking behaviour.
As for BCM reprogramming, you would have to go back to a dealer, or an Independent that has the correct laptop + software for that - if I am not mistaken.
Hope you solve your woes soon.
Post #671716 22nd Aug 2023 8:12am
