![]() | Home > Technical (L405) > rear end sliding |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35486 ![]() ![]() |
it was a a 2 post thing with 4 arms on it Craig...
@Pete, you think its the transfer box then?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8377 ![]() ![]() ![]() |
Not sure TBH, it's a known problem and fix, with very similar symptoms...
thanks for that |
You also need to do the same thing with the wheel jacked up under the bottom wishbone Stan… With suspension on full droop, on a two poster. You can only check how the bushes move when the suspension is in that orientation… Now imagine it on a four poster with the full length beams that lock and allow the wheels to be removed? If they were under the lower wishbones, you would remove weight from some of your suspension bushes, allowing for travel there to be checked too… D3&4 were really bad for the rear bushes allowing the rear axle to essentially self steer! RR should be checked in both droop and compressed to be certain sir… 👍 |
On a different tangent Stan. We are finding more and more 405’s with burst rear dampers! So one side not doing anything! Masked by the ACE system…
no symptoms like yours Alan...
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 771 ![]() ![]() ![]() |
Hi Stan, there is a bug in the IID tool when doing the transfer case calibration. I worked with Pat at GAP to identify a work around for it. What you need to do is start the engine as soon as it automatically switches off during the process. You'll find that it will then complete the calibration process. Kev 2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey 2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
i think i might have done that Kev but not 100% sure..
tried the transfer case [sensor] calibration this morning and still got the error E7..
