Home > Photos, Videos & Media > DPF and EGR delete and remap
DrRob
 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #670059 29th Jul 2023 3:09pm
mjdronfield
Well, hypothetically of course, me likey….. 🤣
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #670064 29th Jul 2023 4:42pm
Mikey
Wonder how much it will cost to reinstate the DPF when the new tests come in?
Post #670084 30th Jul 2023 7:00am
DrRob
I'm tempted by a remap alone to give it a bit more poke but concerns still around 8HP.
Mikey...your thoughts? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #670091 30th Jul 2023 11:43am
JayGee
It will fail an MOT just on the visible amount of smoke when revved or at least indicate to the tester that something is in need of further investigation. Removing the CAT and DPF will help top end power as this is where exhaust flow is the greatest but during normal driving / cruise where the gasflow is low the restriction is insignificant. Any mpg gains on the dash readout with a remap are likley due to the increase in fuel pressure used in the remap which fools the ecu mpg calculations based on inj duration vs distance. 2012 TDV8 Vogue (L322)
Post #670093 30th Jul 2023 11:55am
mgrover
I mean if needs be and it's a simple enough flash via the gap app.
Can we not flash a version that disables the EGR and then for MOT return it in place.
For me am looking purely to disabling the EGR(and ofc extra power/torque never hurts), to clean up the intake for good. Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #671733 22nd Aug 2023 8:19am
GraemeS
Gap couldn't flash the 4.4 late last year.
Post #671737 22nd Aug 2023 9:23am
mgrover
i guess if it needs to be bench flashed its a bit more annoying but it is really that hard if your this dedicated to fiddling around. Its actually a sport Sad
Post #671739 22nd Aug 2023 9:26am
mgrover
another thought on this remap malarky.
Does Sport mode have by any chance a different set of Maps it uses?
Because what would be completely handy is the default map being on Drive, and the 370bhp and 800nm map being the Sport mode.
In this style of map, EGR would be disabled across the board.
Or does Sport really only just hold the revs a bit longer. Its actually a sport Sad
Post #671883 24th Aug 2023 7:02am
JayGee
Sport is just a gearbox program which hold the gears longer and has engine braking rather than overun when off the throttle. GAP can't do remaps for the 4.4 on or off the car. 2012 TDV8 Vogue (L322)
Post #672020 25th Aug 2023 4:54pm
