Home > Maintenance & Mods (L322) > 2010 LED indicator
Clump
England 2010 Range Rover Vogue 4.4 V8 Bournville
2010 LED indicator
Following a minor coming together with a dear the other night (glancing blow, lowish speed, dear ran off presumed ok) the osf indicator on my 2010 l322 has stopped indicating. It worked for a few days afterwards then packed up. Headlamp cover is also cracked and will need replacing.
I can’t work out if the indicator bulb is replaceable, as it’s one of the later LED ones, nor how to physically replace/access it if it is. Is there anything else I should have a look at, with the proviso that I don’t really like fiddling with electrics.
If not replaceable I’m guessing a whole new headlamp unit? Something in the back of my mind tells me that there’s more than one version for the facelift 2010-2012 vehicle. 2010 Bournville Vogue
Post #669777 25th Jul 2023 12:33pm
you'll have to replace the whole light unit ...theres black and grey versions.. ... - .- -.
Post #669782 25th Jul 2023 1:36pm
Clump
Thanks Stan,
Thought this might be the case. Evil or Very Mad
Don’t suppose the you know if the colours were model year specific or where I’d find the part number on the current one? It’s really hard to tell if the current one is grey or black, through the reflection, without a comparison.
I suspect it’s grey. 2010 Bournville Vogue
Post #669793 25th Jul 2023 3:34pm
i dont sorry...possibly theres threads on the forum re this, maybe do a search?
hopefully a forum member might know or could help.. ... - .- -.
Post #669795 25th Jul 2023 4:30pm
mjdronfield
Plus some have cornering lights and some don’t.
The grey or black is year specific. The very last 2012 cars were black if I remember right.
Do you have a pic?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #669802 25th Jul 2023 5:12pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Better pull up a chair when you find out the cost...... Shocked The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #669803 25th Jul 2023 5:14pm
mjdronfield
Some part numbers here, though being a 2012 thread prices will be off a tad 🤣.
https://www.fullfatrr.com/forum/topic12685...=headlight
Bit more info here
https://www.fullfatrr.com/forum/topic65230...=headlight
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #669806 25th Jul 2023 5:32pm
Ask Robin at Duckworths to run your VIN, that will tell you the one you need... Thumbs Up Pete
Post #669810 25th Jul 2023 7:45pm
Clump
Thanks all.
The price is a bit startling, eBay might be my friend. But then there’s the hassle of bumper off installation.
This, combined with the rusty tailgate, dubious gearchange and peeling lacquer mean that it’s days might be numbered 2010 Bournville Vogue
Post #669951 27th Jul 2023 4:43pm
garyRR
I've had the headlights out before on my 2006 (not sure if the 2010 is different). You only need to remove the front grille.
Grab a 2nd hand unit on ebay from a vehicle of the same age. 2015 Range Rover Autobiography 4.4 SDV8
Post #669959 27th Jul 2023 6:33pm
