Home > In Car Electronics (L405) > Sat Nav Volume
AnnualMan
Switzerland
Sat Nav Volume
After reading the manual and previously posting a question, I'm still nowhere closer to solving this one and I have an 8+ hour drive coming up.
How do I reduce the volume of the navigation instructions? I've followed the advice to quickly turn the volume knob down during a voice instruction, but this only reduces the volume for that instruction. As soon as the next instruction comes along its back to the original volume.
Help! I have a two year old who I'm hoping will sleep most of the way! 2018 P400e AB LWB
Post #669909 27th Jul 2023 8:20am
Jase71
United Kingdom 2017 Range Rover Vogue TDV6 Santorini Black
I've got exactly the same issue. I haven't found how to mute it in desperation either! 2017 Range Rover Vogue V6 Diesel
2006 Range Rover Vogue V8 Diesel - gone
Post #669917 27th Jul 2023 9:41am
AnnualMan
Switzerland
For the facelift version I have, muting is done by clicking on the six boxes that overlay on the map, then choosing the 'mute' tile that appears on the next screen 2018 P400e AB LWB
Post #669918 27th Jul 2023 9:56am
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
I haven't tried this in the L405 but in my old D4 I had a similar problem. I found that by leaving the radio 'on' but set at zero volume it would keep the 'adjusted' sat nav volume low. However, if I tuned all audio off, the sat nav would reset to loud with every instruction.
This meant (for the same reason with twin babies in the back!) I could have zero music/radio plus low sat nav announcements.
Not sure if it's the same for the L405 but it might be worth a go. FFRR SDV8 Autobiography
Post #669920 27th Jul 2023 10:09am
go to setup,
system,
volume pre-sets.. ... - .- -.
Post #669922 27th Jul 2023 10:15am
AnnualMan
Switzerland
? No volume presets that I can find 2018 P400e AB LWB
Post #669924 27th Jul 2023 10:18am
main home screen vehicle setup? ... - .- -.
Post #669925 27th Jul 2023 10:41am
PhillV8s
United Kingdom 2013 Range Rover Vogue SE SDV8 Aintree Green
Press setup (button on side of screen)
Then press System
All volume levels are available to set on next screen 2013 SDV8 4.4 Vogue SE Aintree
Post #669936 27th Jul 2023 1:33pm
AnnualMan
Switzerland
I have the facelift L405 so no button on the side of the screen 2018 P400e AB LWB
Post #669937 27th Jul 2023 1:42pm
James W
The > 2017 instructions simply say
I can't find any reference to preset levels in the manual FFRR SDV8 Autobiography
Post #669940 27th Jul 2023 1:56pm
AnnualMan
Switzerland
Exactly what I do, yet the next spoken instruction is back to the original volume level.
I'm now wondering if there's not a minimum volume level you cannot go below? Maybe the volume level I am after is just not available. 2018 P400e AB LWB
Post #669941 27th Jul 2023 2:00pm
you need to find where the volume pre-sets are hidden.. ... - .- -.
Post #669945 27th Jul 2023 3:05pm
M11buc
United Kingdom 2019 Range Rover Autobiography SDV8 Santorini Black
Hi annual man, for what it’s worth. Mine is similar age.
To turn down sat nav volume, wait until there is a spoken instruction then quickly ( while voice is talking) turn to volume you want. There is a volume bar appears. When you adjust it on the Center screen. As I recall the sat nav volume has a green volume line when it pops up. ( the radio/audio has blue or purple colour as I recall)
Once you adjusted the sat nav to volume you want, from there on in, it will always speak to you at that level. Until you adjust again.
Sounds to me like you may have a software issue on your car, if not working as should maybe see how f LR dealer can check software up to date. ?
Post #669963 28th Jul 2023 1:52am
Jase71
Same for me. When the sat nav speaks i turn it down and then the next instruction is back up to the same level. 2017 Range Rover Vogue V6 Diesel
Post #670593 6th Aug 2023 8:59pm
AnnualMan
Switzerland
Was pretty annoying on my long trips last week 2018 P400e AB LWB
Post #670594 6th Aug 2023 9:02pm
