![]() | Home > Technical (L322) > New key syncing |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1233 ![]() ![]() ![]() |
Check out some of the info in these threads, links below, this may help you - You don't need any more bits apart from maybe a device that can clear the key synch address list, as if it's full you cannot synch another key, or the procedure you used was incorrect, the below may help -
