Home > Maintenance & Mods (L322) > tail gate |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 |
Tailgate is not automatic. Just unlatches off the button.
18th Jul 2023 5:36pm |
dazk2001 Member Since: 17 Jul 2023 Location: maidstone Posts: 24 |
Thanks just wondered if the gas strutts had gone as have to lift the door up
19th Jul 2023 3:34am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1538 |
Very likely the struts have lost pressure. They are cheap from aftermarket sources and quite easy to replace. The hardest part is holding the tailgate open while replacing. Get an assistant or a length of wood.
19th Jul 2023 5:20am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
You have to lift it but it should not take much effort and as others have said the struts are cheap and easy to fit. Also check the bonnet struts. A flashing fault on the parking sensor system generally means a wiring fault on the sensor which is due to their terrible design. A GAP IID tool will tell you which one it is. A fix requires removal of the bumper so hope it's a rear sensor as the front bumper is a PITA to remove. The rear cam does stay on for a bit once drive is engaged but should go off eventually 2012 TDV8 Vogue (L322) |
19th Jul 2023 7:56am |
thanks fo rthe reply
19th Jul 2023 4:24pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8358 |
Yep, defo worth it and always worth a good price second hand on here.... Pete
19th Jul 2023 4:31pm |
can you point me to the for sales |
20th Jul 2023 4:07am |
^^ See https://www.fullfatrr.com/forum/for-sale-wanted-vf11.html Ron B. VK2OTC
20th Jul 2023 5:52am |
