Home > Technical (L322) > Restricted Performance (Amber) Warning, but! no power loss
CMC15
Hi All, strange one for you all.
2011 TDV8, 70k miles has started throwing up an amber restricted performance warning upon engine restart over the last couple of days (incidentally with a small trailer attached but cant see how that could be related).
The car has has the new 4 silicone hoses and donut high pressure smoke test done 12 months ago, so I don't think that is the issue (after a red warning came up and limited to 2500rpm).
After I unplug the trailer (again I think this is coincidence) the warning goes and is gone for a few days.
I've checked where I can see for split hoses and all looks good, aging there is no actual loss in power/drivability.
Car does long runs so I believe the DPF is fine (never had a warning come up).
Any ideas?!
Time to finally invest in a GAP tool I think..........
Chris
Post #669337 18th Jul 2023 2:27pm
DrRob
Or take it to James Henshall at Henshall Engineering. Guru Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #669346 18th Jul 2023 6:01pm
garyRR
Investment in an IID may help pinpoint cause, as it could be anything causing the restricted performance message (such as a faulty sensor).
Did you also check the union on the throttle body, as that seal fails too? 2015 Range Rover Autobiography 4.4 SDV8
Post #669355 18th Jul 2023 8:26pm
JayGee
Re: Restricted Performance (Amber) Warning, but! no power lo
CMC15 wrote:
Any ideas?!
Chris
You answered you own question Thumbs Up 2012 TDV8 Vogue (L322)
Post #669367 19th Jul 2023 6:17am
RichTD6
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Could be the water in fuel sensor going bad, I’ve started getting the same warning randomly lately and the fault code shows this is the issue. No noticeable loss of performance despite the warning. As all above have advised though, code reader is the way forward.
Rich 2012 Westminster TDV8 4.4 Indus Silver
GAP IID Bluetooth Tool
Previous Range Rovers:
2005 L322 Vogue SE TD6 Zambezi Silver
1995 P38A HSE Epsom Green
1988 Classic Vogue EFi Cassis Red
1973 Two Door Tuscan Blue
Post #669501 20th Jul 2023 7:00pm
