![]() | Home > Maintenance & Mods (L322) > Secondary oil pump |
Separate oil pan is to stop oil not draining from turbo when on steep ground.
Shaunj69 Member Since: 25 Feb 2022 Location: Bristol Posts: 57 ![]() ![]() ![]() |
Hi JayGee
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
This is well-covered in the article here: https://www.fullfatrr.com/forum/topic40047-180.html
If it's just grey it's not leaking into the compressor (cold) side and it's just oil evaporating in the hot exhaust which is how most people experience this issue. Save you money to spend on the ULEZ or don't rev past 2400rpm - I've managed to drive months without needing the 2nd turbo.... 2012 TDV8 Vogue (L322) |
As for the ULEZ in bristol, my car is exempt lol sorry L322 TDV8 2011 Autobiography
Hopefully you saw my post Shaun and linked thread where there's been a recent discussion on the vacuum pump (and long running discussion on turbo drain mod). 2015 Range Rover Autobiography 4.4 SDV8 |
Hi Gary
