![]() | Home > Maintenance & Mods (L322) > Viscous fan removal |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Order your self the holding spanner mate. Costs about £20 but really makes life so much easier. It goes round the bolt heads then get your 36mm spanner and crank it off. Remember they are usually a left hand thread tho mate |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Yes don't forget to turn it to the right to undo it sir... Opposite thread |
GrunterNI Member Since: 30 Oct 2020 Location: Co Down Posts: 48 ![]() ![]() ![]() |
Thanks for the replies guys |
Appreciate its an extra cost but really does make life so much easier then using the traditional method of stick a spanner on and whacking it with a club hammer to shock it off. Used this method one n after I missed the spanner and hit my hand I thought sod it, I'll get the holding tool
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1538 ![]() ![]() |
The easy way to remember which way to turn it is - undo in the same direction that it normally rotates. Works for serpentine and V-belt fans. I made a viscous coupling holding tool from a design on FullFatRR. I'll try to find the thread. Found it - it was from a site which doesn't appear to be around any more: http://greenoval.homeunix.org/rr/Rad_Rep/Spanner.jpg Someone might know if it has been renamed. Here's a scan of the file: https://www.fullfatrr.com/gallery/albums/u...anner6.pdf Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
