Home > Technical (L322) > Engine Management Fault
Byg Nyge
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
I have an 'Engine Management Fault' show up on the dash, it goes off after a few moments but the performance is slightly restricted. No warning lights light up. It seems to after a certain driving time and is irrespective of driving style. It comes on while driving the lanes, towing my caravan at a set 50mph on cruise control and sometimes when I kick it to overtake something. It resets after cycling the ignition.
It's an'07 TDV8 3.6
Post #668216 3rd Jul 2023 2:36pm
JayGee
We need codes to make any diagnosis. A generic code reader may help but any competent garage should be able to do this for you. Best still is to get yourself a GAP IID tool and DIY. 2012 TDV8 Vogue (L322)
Post #668226 3rd Jul 2023 3:16pm
Byg Nyge
I have a ThinkCar Diag 2 I did a diag last wednesday and couldn't see anything pertinant, I'll have a look tomorrow. it's going in for a service on thursday would they do a diag on it as a matter of course?
Post #668231 3rd Jul 2023 4:12pm
JayGee
Not unless you ask them but they should reset the service interval so will at some point plug in a diagnostic tool. 2012 TDV8 Vogue (L322)
Post #668232 3rd Jul 2023 4:26pm
Byg Nyge
The saga continues - went in for service yesterday (Thursday) Everything ok until they changed the fuel filter. cannot be driven, fuel pressure too high P0088? fault code,never had that one before. Garage at a loss as to why.
Post #668575 7th Jul 2023 11:08am
garyRR
Fuel pressure too high would suggest the high pressure fuel pump being an issue or a faulty injector (or two) and may explain the problem occurring under load or randomly.
I would have thought the garage should be suggesting testing the pressure from the HP pump first and then secondly, a leak off test as the next steps. 2015 Range Rover Autobiography 4.4 SDV8
Post #668581 7th Jul 2023 11:35am
Byg Nyge
All sorted, looks like the PCU? had a brain fart and threw up the code. Battery disconnected overnight fault gone, put 100 miles on it this morning round the doors and lanes and a motorway jaunt no problems. Fingers crossed.
Post #668662 8th Jul 2023 1:11pm
Byg Nyge
And back in the room, all good for a few days and the fault re-appears, took it to a local LR Specialist and he used his super dooper computer and reckons the probable fault is the EGR valves all caked up and sticky (a bit like meself!) they're going to do an EGR delete and re-map and he reckons that will do the job. Fingers crossed.
Post #670447 4th Aug 2023 1:10pm
